configure identity-management role
configure identity-management role role_name { tag [ tag | none] } {vr vr_name | none ] }
Description
This command defines VLAN/VR membership to an identity management role.
Syntax Description
role_name Name of the role.
tag VLAN tag for dynamic VLAN creation for this role.
tag VLAN tag between 1 and 4094.
vr Virtual router name for dynamic VLAN creation for this role.
vr_name Virtual router name.
none None.
Default
N/A.
Usage Guidelines
Use this command to configure VLAN tag and the VR in which the dynamic VLAN has to be created for a role. By default the dynamic VLAN is created in VR-Default if the VR is not configured. The identity is placed in the base VLAN if no VLAN tag is configured for this role. The configured VLAN tag and VR can be set to none to unconfigure the same. VR-Mgmt is not allowed to configure. The VLAN tag and VR is applicable only to the user created roles.
The following example configures role "r1" and tag 100:
# configure identity-management role "r1" tag 100 vr "VR-Default"
This command was first available in ExtremeXOS 15.4.
Platform Availability
